wflather
Feb 11, 2018Tutor
Genie won't connect to OpenDNS for Parental Controls
I get I know there is already a good thread on this subject, but this !@*&($@#*&#& forum app WON'T let me add my question to that thread. So we get a new thread, sorry. I am using the PC versio...
- Feb 21, 2018
Solution found:
Emailed support at: [email protected]
They called while I was out of town, also emailed with a link to provide workable callback time and phone number as well as requested some basic system information.
Tech called back right on time.
Very polite and knowledgeable.
Had me download and run a remote control app so he could directly manipulate my system.
Updated firmware on router (even though router indicated firmware was up to date).
Tech took the time to back up the router settings first.
Re-downloaded latest Ver of Genie, which failed to work.
We confirmed that I had the correct OpenDNS login/pw by directly accessing OpenDNS through their website.
Uninstalled Genie, downloaded older version (2.4.38) from here: https://files.netgear-support.com/go/index.php?action=d&step=3
Installed this version.
This version of Genie connected successfully with Router and OpenDNS (after a couple tries, I probably entered password wrong)
Genie is now working correctly.
Support this time was A+ in quality.
Thanks!
wflather
Mar 21, 2018Tutor
email support at: [email protected]
I had a very good experience with email and phone support. Total opposite of this "Community" support. Received an email response asking for a good time to call, then they called back almost right at the designated time. Tech was able to get the mess working within a resonable amount of time.
Analytic_Al
Mar 25, 2018Aspirant
The link you provided for old version of Genie requires a login, my Netgear login doesn't work, can you provide a working link for old version of Genie, or where did you get the login?
"Uninstalled Genie, downloaded older version (2.4.38) from here: https://files.netgear-support.com/go/index.php?action=d&step=3 "
I believe I have the same issue with Genie versioning. My network and devices have worked for 2 years with Genie, parental controls, bypass login and OpenDNS.
I added a new PC, downloaded Genie from Netgear website this week, and this version of Genie won't login to OpenDNS or Parental controls on this PC. Other PC's and devices are still working perfectly, and my web OpenDNS and bypass logins work.
I just can't use Genie to add bypass login on this new PC
