wflather
Feb 11, 2018Tutor
Genie won't connect to OpenDNS for Parental Controls
I get I know there is already a good thread on this subject, but this !@*&($@#*&#& forum app WON'T let me add my question to that thread. So we get a new thread, sorry. I am using the PC versio...
- Feb 21, 2018
Solution found:
Emailed support at: [email protected]
They called while I was out of town, also emailed with a link to provide workable callback time and phone number as well as requested some basic system information.
Tech called back right on time.
Very polite and knowledgeable.
Had me download and run a remote control app so he could directly manipulate my system.
Updated firmware on router (even though router indicated firmware was up to date).
Tech took the time to back up the router settings first.
Re-downloaded latest Ver of Genie, which failed to work.
We confirmed that I had the correct OpenDNS login/pw by directly accessing OpenDNS through their website.
Uninstalled Genie, downloaded older version (2.4.38) from here: https://files.netgear-support.com/go/index.php?action=d&step=3
Installed this version.
This version of Genie connected successfully with Router and OpenDNS (after a couple tries, I probably entered password wrong)
Genie is now working correctly.
Support this time was A+ in quality.
Thanks!
wflather
Apr 07, 2018Tutor
You should email support at [email protected]
They had a tech call me, he solved the issue. As bad as the support forum is, the email and phone support was just the opposite, very good.
junitz
Apr 07, 2018Aspirant
Thanks.... I will give it a try.
- kingkApr 08, 2018Aspirant
Genie OpenDNS parental controls not working.
New NightHawk app only mentions Circle.
Looks to me like Netgear is discontinuing the OpenDNS parental controls.
Some notification would have been nice instead of silently disabling it with updates.
