wflather
Feb 11, 2018Tutor
Genie won't connect to OpenDNS for Parental Controls
I get I know there is already a good thread on this subject, but this !@*&($@#*&#& forum app WON'T let me add my question to that thread. So we get a new thread, sorry. I am using the PC versio...
- Feb 21, 2018
Solution found:
Emailed support at: netgearteam@netgear.com
They called while I was out of town, also emailed with a link to provide workable callback time and phone number as well as requested some basic system information.
Tech called back right on time.
Very polite and knowledgeable.
Had me download and run a remote control app so he could directly manipulate my system.
Updated firmware on router (even though router indicated firmware was up to date).
Tech took the time to back up the router settings first.
Re-downloaded latest Ver of Genie, which failed to work.
We confirmed that I had the correct OpenDNS login/pw by directly accessing OpenDNS through their website.
Uninstalled Genie, downloaded older version (2.4.38) from here: https://files.netgear-support.com/go/index.php?action=d&step=3
Installed this version.
This version of Genie connected successfully with Router and OpenDNS (after a couple tries, I probably entered password wrong)
Genie is now working correctly.
Support this time was A+ in quality.
Thanks!
m2jel
Apr 11, 2018Aspirant
I emailed them a week ago, no response.
Since it looks like the problem is with the current version of Genie (PC), I uninstalled what I had, ran CCleaner and then installed a downloaded version of Genie I had from July 2017.
With the older version of Genie, I logged into Parental Controls without a problem and was able to make changes to the filtering level of each of my devices.
Geesh! I'm getting fed up with Netgear - first there was the wifi dropping off back in November that seemed to finally cure itself in January (after I dropped another $275 on a new modem/router because I thought my old one was causing the problem); and now the parental controls with OpenDNS that they won't seem to acknowledge! :smileymad:
Analytic_Al
Apr 12, 2018Aspirant
"Since it looks like the problem is with the current version of Genie (PC), I uninstalled what I had, ran CCleaner and then installed a downloaded version of Genie I had from July 2017.
With the older version of Genie, I logged into Parental Controls without a problem and was able to make changes to the filtering level of each of my devices."
I think this is exactly correct. I have two Windows 7 PC's and an Android phone running an old version of Genie, OpenDNS works fine there, and I can edit the Parental controls and access the Bypass login. I got a new Windows 10 PC and installed the current version of Genie, it won't login to OpenDNS. Does anyone have an old version of Genie for Windows 10? Prior versions aren't available on the Netgear website and I can't find one online. FYI the filedropper link posted above downloads a 0byte file for me. My router is past the initial free service window and I don't want to access paid support... but if someone from Netgear reading this could make available a prior version of Windows 10 Genie I would install and test it. Thanks!
- DanKI6XApr 22, 2018Tutor
The workaround I use (hope it gets fixed properly though, the latest Genie update 2.4.54 still has the login issue with OPENDNS):
Log into router via web browser: 192.168.1.1
Use Parental Controls from there (you login to OPENDNS fine this way)
Dan
- wflatherApr 22, 2018Tutor
The parental controls provided by the router itself do work, although if you add meaningful names to devices it seems to forget them, which is a total PITA. Please be aware that the IP address you use is an internal one, other users may use a different scheme, such as 192.168.0.1 or 10.0.0.1. Either are pretty standard, but I think Netgear usually defaults to the 192.168.n.n scheme.
