Rands100
Oct 03, 2016Aspirant
Ios10 + genie
Since updating my iPhone to ios10 netgear genie doesn't work. Any ideas? Thanks
- Oct 25, 2016
Hi Rands100,
Thank you for responding. The remote login through the Genie app feature is currently only supported by the following router models:
R6250
R6400
R6700
R6900
R7000
R7300DST
R7800
R7900
R8000
R8300
R8500
R9000You may refer to the article linked below.
http://kb.netgear.com/app/answers/detail/a_id/26109
Dexter
Community Team
Alexsanders
Oct 10, 2016Aspirant
Rands, are you getting lines where numbers used to appear inside the app or will it just not load at all? I'm having a similar issue if it's the lines.
