Arcuri
Jun 29, 2022Follower
Netgear D6000
Hi there, Im trying to set up my netgear D6000 budt ot says to check the cables and try again. Everything is connected. Do you guys know how to fix it?
michaelkenward
Jul 02, 2022Guru - Experienced User
You have posted this in the "genie" section. Is that because you are using one of the various genies to set up your modem router? If so which one?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
DSL Modems & Routers
