Dorus
Nov 05, 2015Tutor
Netgear genie + webpage Nighthawk
Hello, Why is the wifi password vissible in netgear genie and the wegpage of the nighthawk? Even when not logged in. Why not use ******** ? Thx.
- Nov 13, 2015
If Netgear designed it this way.......... oke, it's a choice.
But i find it not sensible.
Scrolling it the whole time is a security breach.
I often use netgear genie to see who is connected.
Ipadres, Mac address, etc.
So netgear genie webpage is open on my laptop.
If users can access the netgear genie tool (by login) they can also change the password if necessary.
Again, scrolling it on a top webpage ...................????????
DexterJB
Nov 06, 2015NETGEAR Moderator
Hi Dorus,
The Wi-Fi password is only viewable if you are logged in on the NETGEAR Genie app/program and the case is the same with the UI on the browser. The reason for this is accessibility in the event that you forget the Wi-Fi password, it will be retrievable without resetting the device.
Dexter
Community Team
Dorus
Nov 06, 2015Tutor
I don't follow you.
If the session (Genie webpage) is expired, the wifi password is stil scrolling in de webbrowser screen.
I understand that, for security reasons the password of Genie webpage will expire after a While.
But why is the wifi password still vissible.
And beside of that there no need to scroll the wifi password at this point.
