Dorus
Nov 05, 2015Tutor
Netgear genie + webpage Nighthawk
Hello, Why is the wifi password vissible in netgear genie and the wegpage of the nighthawk? Even when not logged in. Why not use ******** ? Thx.
- Nov 13, 2015
If Netgear designed it this way.......... oke, it's a choice.
But i find it not sensible.
Scrolling it the whole time is a security breach.
I often use netgear genie to see who is connected.
Ipadres, Mac address, etc.
So netgear genie webpage is open on my laptop.
If users can access the netgear genie tool (by login) they can also change the password if necessary.
Again, scrolling it on a top webpage ...................????????
Dorus
Nov 13, 2015Tutor
DexterJB
Nov 13, 2015NETGEAR Moderator
Hi Dorus,
You always have the option to logout either on the browser UI or the NETGEAR Genie program so that others will no longer have access to the router settings not unless they know your router password. So, I would also suggest changing your router password as additional security.
Dexter
Community Team
