Jonnoza
Oct 16, 2016Aspirant
Netgear Genie Authentication Problem
When logging via a browser I can access my router. If I try via iPhone or iPad genie app I get th message "login failed. Please enter in the correct Admi password". Password gives access via the bro...
- Oct 24, 2016
With the new App update to version 2.4.38 the problem has been resolved.
Thank you
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi Jonnoza,
Please try uninstalling and reinstalling the app. If the issue persists, please reboot the router and try logging in through the app again.
Dexter
Community Team
- JonnozaOct 20, 2016Aspirant
Thank you
Have done all of the above. Waited for a Genie app update, hoping this would solve the problem. Factory reset of router.
I can access the router with PC, iPad, iPhone using a web browser. But the Genie app will not accept the same password that is used to access the router using a browser.
- DexterJBOct 20, 2016NETGEAR Moderator
Hi Jonnoza,
Thank you for responding. We are currently investigating this. Please make sure you keep the app up to date for possible fixes.
Dexter
Community Team
- JonnozaOct 24, 2016Aspirant
Thank you
