RYza's avatar
RYza
Netgear Genie PC Windows Command Processor Pop Ups
Hi, Sometimes when my internet is down and I reconnect it with the Netgear Genie app (Ver. 2.4.60)  I'll get very frequent Windows Command Processor Popups which are extremely annoying. It asks "...
  • schumaku's avatar
    May 03, 2019
    Frequent? It does happen only when Genie is launched.
    RYza wrote:
    It asks "Do you want to allow this app to make changes to your device?" (See photo)
    Not a risk - this happens because of a user space application does have to launch a daemon (a system background process) - and Windows UAC will jump in as this requires higher privileges.
    Root cause is a lazy program installation system - much better would be if Netgear would launch the daemon along with the system start. Christian_R  ChristineT that's one of several flaws in the Netgear Genie (desktop) version.
