Robert440
Jul 16, 2022Aspirant
Netgear Genie Program shuts down during use.
I'm running Netgear Genie on Windows 10. In the past the program has worked fine. I've been attempting to set up a VPN network for cameras and now the Netgear Genie program will start just long enoug...
Robert440
I've been goofing around with this all day. I finally got the WIFI Analytics page to stay open but none of the other pages will stay open longer then 15 seconds!
- michaelkenwardJul 17, 2022Guru - Experienced User
Tried reinstalling the genie?
If you have lost the installation files, get it from here.
genie | Product | Support | NETGEAR
It comes as a rar file, which needs unpacking and that can confuse people.
- Robert440Jul 26, 2022Aspirant
Thanks for the info. I extracted that file and all of a sudden Genie started to work. It only lasted 1 session and then it started to do the same thing. I then uninstalled and reinstalled and nothing changed. I'll keep trying. Thanks
