insainzeno
Dec 29, 2020Aspirant
Netgear Genie showing over 1900 connections
I've had this netgear CM500 modem for 2 years now. All of a suddent I've started to have issues with connectivity. I called my ISP but they said everything is fine on their end. I then tried switchin...
- Jan 21, 2021
michaelkenward wrote:Freaky.
Perfectly correct - the Genie (desktop) program is right - all these computers are on the same subnet.
michaelkenward wrote:But the CM500 is just a modem. The network map will be down to the router. What is it?
Correct again. Lack of a NAT router, the modem does connect to the cable company headend, hand-out one Public IPv4 address (for one computer or for one router WAN/Internet port).These addresses are from your ISP (rcn.com/rcn.net) assigned IP-Network-Block 66.44.8.0 - 66.44.15.255. A cable headend is connecting a large amount of clients, so big IP subnets are nothing uncommon. /21 or /20 subnets on a single RF headend are typical, this makes 2046 available addresses on a /21 (255.255.248.0) or 4094 available addresses on a /20 (255.255.255.240.0) subnet.
michaelkenward wrote:Have you tried searching for all those IP addresses? Half the planet seems to be running on your network.
No, just some thousand customers from that very same ISP.
insainzeno nothing wrong, nothing to worry - except that you must ensure your computer firewall is configured to connect to a public network.
Dec 30, 2020Guru - Experienced User
Please post about this over in the Genie forum:
https://community.netgear.com/t5/Genie/bd-p/home-genie
Is there a wireless router connected between the modem and your PC? Doesn't look like it ,thus Genie is seeing everything else on the modems network in your nieghborhood with your PC directly connected to the back of the modem? Put a wifi router in between the modem and your PC.
Good Luck.
