oguidry
Sep 18, 2015Initiate
Netgear Genie Too Small
Have been using and liking Genie with my home network. Just bought a Dell XPS 13 laptop. Installed Genie. It appears in the center of the screen but it is tiny. It is about 2 inches square on a 1...
- Jul 28, 2016
What worked for me:
Check the 'Run this program in compatability mode for: Windows Vista'
Be sure to kill it via Task Manager, then restart.
JayCee47
Jul 28, 2016Initiate
What worked for me:
Vulcan5s
Jul 29, 2016Aspirant
you my friend, are a genius. it worked for me as well surprisingly! thanks!
- aalexandrebetaJul 30, 2016Master
Netgear should be completly rewritten this is one of the major issues of that program I do not know why we call it app today!
- Vulcan5sJul 31, 2016Aspirant
on a semi related topic....does anyone know how to scale the text in the drop down boxes for sites like amazon or ebay? the text appear really small in these boxes.
my display is already set to 250% (recommeded) but the characters in these boxes still appear very small.
thanks!
- aalexandrebetaAug 02, 2016Master
This program that is how it should be called should auto-resize acording to the definition of the screen!
an app should never appeared and progrm is a program period!
