oguidry
Sep 18, 2015Initiate
Netgear Genie Too Small
Have been using and liking Genie with my home network. Just bought a Dell XPS 13 laptop. Installed Genie. It appears in the center of the screen but it is tiny. It is about 2 inches square on a 1...
- Jul 28, 2016
What worked for me:
Check the 'Run this program in compatability mode for: Windows Vista'
Be sure to kill it via Task Manager, then restart.
Abby123
Sep 20, 2015Aspirant
I'm having the same problem. I just purchased a new Dell Inspiration 7000 4k video and the genie screen is so small. Can't figure out how to expand or make larger and it's too small to read. Any suggestions on making larger?
- DexterJBSep 21, 2015NETGEAR Moderator
You may try the steps below as a work around and check if it fixes the issue.
1. Right click on the NETGEAR Genie app icon on the desktop and select Properties.
2. Click on the Compatibility tab.
3. Check the box for Disable display scaling on high DPI settings.
4. Click Apply then OK.
5. Exit the NETGEAR Genie app by right clicking on the icon on the system tray and select Exit.
6. Open the app again and check if it worked.
7. If it did not, you may follow the same steps from 1 to 2 then check the box for Run in 640 x 480 resolution and follow steps 4 to 6.
Dexter
Community Team
- oguidrySep 22, 2015Initiate
Sorry but these did not work. The new device notifications are also very small. Other thoughts?
- DexterJBSep 22, 2015NETGEAR Moderator
Hi oguidry,
The current NETGEAR Genie desktop application has not yet been coded to be DPI aware which may cause these issues with high resolution screens. I recommend keeping an eye out on the next update for the app in the event that a fix has been pushed out.
Dexter
Community Team
