paperquill
Apr 16, 2021Aspirant
netgear genie
Hello,netgear genie won't accept my username which it says is my e-mail address,My e-mail address has not changed since I bought the router.
- May 07, 2021
Sure---As somrone in the community suggested I did a factory
reset and then followed the instructions in the router manual.
It worked out fine.
Thank you.
Christian_R
Apr 22, 2021NETGEAR Employee Retired
Hello paperquill,
May you try the default credentials below.
Username: admin
Password: password
Christian
- paperquillMay 06, 2021Aspirant
hankkkk
thank you.i did find a fix.
- michaelkenwardMay 07, 2021Guru - Experienced User
That's good news.
Care to share it with as? You could save someone else from going through the same problems.
- paperquillMay 07, 2021Aspirant
It worked out fine.
Thank you.
