paperquill
Apr 16, 2021Aspirant
netgear genie
Hello,netgear genie won't accept my username which it says is my e-mail address,My e-mail address has not changed since I bought the router.
- May 07, 2021
Sure---As somrone in the community suggested I did a factory
reset and then followed the instructions in the router manual.
It worked out fine.
Thank you.
michaelkenward
Apr 23, 2021Guru - Experienced User
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
What are you doing and what happens?
Unfortunately, "won't accept" doesn't tell us what error messages and prompts you see.
- paperquillApr 28, 2021Aspirant
Thank you for the info.
