paperquill
Apr 16, 2021Aspirant
netgear genie
Hello,netgear genie won't accept my username which it says is my e-mail address,My e-mail address has not changed since I bought the router.
- May 07, 2021
Sure---As somrone in the community suggested I did a factory
reset and then followed the instructions in the router manual.
It worked out fine.
Thank you.
paperquill
May 06, 2021Aspirant
hankkkk
thank you.i did find a fix.
michaelkenward
May 07, 2021Guru - Experienced User
That's good news.
Care to share it with as? You could save someone else from going through the same problems.
- paperquillMay 07, 2021Aspirant
It worked out fine.
Thank you.
