frankflores
Apr 14, 2023Aspirant
netgear genie
I can not get to netgear genie by using run command and the router IP. I can use the browsers Chrome and Edge to get to it. In the past I was able to use the run window short cut to get to the rou...
michaelkenward
Apr 15, 2023Guru - Experienced User
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
What are you trying to achieve?
- frankfloresApr 18, 2023Aspirant
I have posted a JPEG of the one I have.
Not sure which one it is.
I want to be able to use the RUN window to get to it like I used to do.
It was a short cut where I would open the run window and select the IP for the router.
