BEANBER
Jul 01, 2018Aspirant
Netgear R6100
I had a power outage in my area. My router rebooted and had to re-connect all my electronics. Everything seems to be working under guest wifi. The router will not let me sign in to the main accounts w...
- Jul 02, 2018
BEANBER wrote:
I had a power outage in my area. My router rebooted and had to re-connect all my electronics.As the power cut will also have affected the modem, did you restart everything in the right order?
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
I find that my modem sometimes kicks in after the router is up and running, which means that the network configuration is all wrong.
michaelkenward
Jul 02, 2018Guru - Experienced User
BEANBER
Jul 02, 2018Aspirant
That fixed it. Thank you.
- michaelkenwardJul 03, 2018Guru - Experienced User
That's good.
I have become intimately familiar with that problem. Four power cuts, mostly short blips, in three days meant that my network rebooted itself. The router always kicked in before the modem had done its thing.
It would be nice to have a way of delaying the router's intervention for a bit.
