PeteOJ
Apr 25, 2024Tutor
Netgear R6200 firmware issue
Hello i have a netgear router model R6200 running Firmware version: 1.0.0.28_1.0.24 i tries to update the firmware to R6200-V1.0.1.56_1.0.43 i browse the firmware that was on local pc it start ...
PeteOJ
Apr 25, 2024Tutor
hello
i get also a version R6200-V1.0.1.58_1.0.44 downloaded
im not infront of the router
Apr 25, 2024Guru - Experienced User
PeteOJ wrote:
hello
i get also a version R6200-V1.0.1.58_1.0.44 downloaded---I mean just a couple newer than the one on there. not all the way from the start to the newest.
im not infront of the router ----We'll you'll need to be to try a factory reset. we also recommend doing any firmware changes over a hardwired connection
- PeteOJApr 25, 2024Tutor
i dont see a newer version on the netgear site for this model
everything is working but i get site cannot be reached
Thanks
- plemansApr 25, 2024Guru - Experienced User
1. I didn't say install the newest. I said install a couple versions newer than you had. You're on the .28 version. Don't go all the way to the newest. Try installing the .48 version instead. Not the .58.
2. If you can't access it, try the factory reset. Anytime there's an issue after a firmware change, that's one of the first things recommended as old settings can cause issues.
PS. It might be time to keep an eye out for a newer router. that device was released in 2012. Its getting a bit older and isn't the highest performing device either.
Hello
it work with the 6200-V1.0.1.58_1.0.44 everything is fine now
Thanks
