PeteOJ
Apr 25, 2024Tutor
Netgear R6200 firmware issue
Hello i have a netgear router model R6200 running Firmware version: 1.0.0.28_1.0.24 i tries to update the firmware to R6200-V1.0.1.56_1.0.43 i browse the firmware that was on local pc it start ...
Apr 25, 2024Guru - Experienced User
PeteOJ wrote:
hello
i get also a version R6200-V1.0.1.58_1.0.44 downloaded---I mean just a couple newer than the one on there. not all the way from the start to the newest.
im not infront of the router ----We'll you'll need to be to try a factory reset. we also recommend doing any firmware changes over a hardwired connection
PeteOJ
Apr 25, 2024Tutor
i dont see a newer version on the netgear site for this model
