Angelswm
Oct 27, 2018Follower
NetGear R6400 - shows not connected to internet but it is!
I’m having issues with my netgear router. It’s showing all my devices are connected on the genie map but there is a red line from the globe to the devices. Most of my devices are not working on WiFi. ...
- Oct 29, 2018
Hi Angelswm,
Welcome to the community!
1. What is the current firmware version of the router? This link may help.
2. What is the status of the Internet LED? Page 10 of the user manual here may help.
3. Do you have other devices that can go online without any issue?
4. Have you tried resetting the router?
Dexter
Community Team
CruisewithBill
Nov 17, 2018Aspirant
The expander works after the router is reset but a couple days later it still shows as connected in settings but my Ipad and Iphone do not connect to the wifi even though it shows a strong signal?
DexterJB
Nov 20, 2018NETGEAR Moderator
Hi CruisewithBill,
1. Please indicate the exact model number and firmware version of both your router and extender.
2. When you say "reset", are referring to doing a factory reset or just turning the device off and on?
3. Are your devices trying to connect to the main router or the extender?
4. Do you have other devices that work fine when connecting to either the router or the extender?
Dexter
Community Team
- DexterJBNov 29, 2018NETGEAR Moderator
Hi CruisewithBill,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
