TimSuther
May 05, 2021Guide
Nighthawk 7800 & xfinity
My firmware (currently v3.01.43) is not most current. Netgear app indicates that only my ISP (xfinity) can do upgrade. Xfinity, being xfinity, says since they didn't provide router, they can't upgrad...
May 05, 2021Guru - Experienced User
1. per the docsis spec, only the ISP can push the update. Its not something netgear controls. They submit updated firmware to the ISP but they can't force them to update. And they rarely do as it costs the ISP $ to certify devices. And they're very good as saying "its not our fault". Which from the technician's point of view that you talk to, they're correct. But its not something netgear can do.
2. Do you have a screen snip of the cable connections page and the event logs? That helps check the signal and the logs.
3. Does it happen at exactly the same time each day? or does it vary?
4. How old is the device?
TimSuther
May 05, 2021Guide
Thanks for prompt reply. Device bought in Feb 2021. Instability does not happen at the same time every day, nor at same frequency (some days, like today, 10+ reboots; others might be once a day)
id need to track down cable connections page / event logs. Have never done that before: possible to point me in the right direction?
- plemansMay 05, 2021Guru - Experienced User
when you first log into the router, click on the internet icon on the screen. It'll take you to the cable connections page. Get all that info in a screens shot (might take more than 1)
to get the event logs follow this guide: https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
get screen snips as they're easier to read/interpret.
