Titanhansen
Apr 12, 2018Follower
Parental Controls not working
Hi, I am trying to setup parental controls, but I get an error message when connecting to OpenDNS. My account works fine on opendns.com, anyone knows what to do? I am using firmware V1.3.0.10...
- Jul 24, 2018
Hi Townsend96,
1. What is the model number and firmware version of your router?
2. If your router supports the Disney Circle feature (list of routers are here), then you can look into it here.
3. If not, you can use a combination of features. See below.
First, you can do Address Reservation for your devices and set them on a range (i.e. 192.168.1.2-192.168.1.10). Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24091
Second, set a schedule (i.e. 22:00 to 06:00). Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24055
Third, set to block all services. Steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
DexterJB
Jul 18, 2018NETGEAR Moderator
Hi all,
1. Does the issue persist when you try logging in using another device (iOS, Android, PC, Mac)?
2. Are you using an existing OpenDNS account or was it setup using the NETGEAR Genie app/program?
3. Have you tried uninstalling and re-installing the app/program?
Dexter
Community Team
- DexterJBJul 23, 2018NETGEAR Moderator
Hi all,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team - Townsend96Jul 23, 2018InitiateThanks Dex.,
I finally ended up getting the filter level set for my family. I ended up logging into open dns website on my laptop. Added my network. Then I logged on with the Netgear app and it worked. Now I can't figure out how to put a time limit on a device for bedtime. Would you be able to help? Thank you!- DexterJBJul 24, 2018NETGEAR Moderator
Hi Townsend96,
Dexter
Community Team
