carbonunit
Jul 24, 2022Aspirant
R6100 access router
Hi I'm trying access my router is the genie app obsolete when I go to that page it is blank also if I go to routerlogin.net I get a warning that it is a unsecured page ?? Its been awhile since Ive tried to set anything up, add networks etc. Also is this model robust enough to run directtv stream ? I'm suppose be getting 100 megs from spectrum internet. THX for any tips/advice
You can access it through the browser.
You get that notice because its being accessed using http and not https
You're on a local network though so its find to click on the continue option.
The R6100 will handle 100mbps fine. Its not going to handle more than that though because its only 10/100mbps device and not gigabit.
1 Reply
