Jim6250
Jan 30, 2016Aspirant
R6250 access control in Genie
I have an R6250, using latest firmware V1.0.4.2_10.1.10. For some reason, Access Control is not available in Genie. Direct Web version, under Advanced/Security there is no access control as see...
- Jan 30, 2016
Hi @Jim6250,
The Access Control feature of the NETGEAR Genie will only work with firmware versions which have that option under Security > Access Control. If you want to completely remove access to the Internet, you can perform Address Reservation then setup a schedule to block all services (includes Internet) on a specific IP address range. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24055
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
DexterJB
Jan 30, 2016NETGEAR Moderator
Hi @Jim6250,
Dexter
Community Team
- Jim6250Jan 30, 2016Aspirant
Thanks, I suspected as much, considering the function was missing in both places.
Any way to tell if the firmware is under development enough that it gets full functionality (and not just bug fixes)?
- DexterJBJan 31, 2016NETGEAR Moderator
Hi @Jim6250,
For as long as a device is not yet on EOL (End of Life) status, then it may continue to receive firmware updates and fixes. You can check this on the product page.
http://support.netgear.com/product/r6250
Dexter
Community Team
- Jim6250Jan 31, 2016Aspirant
OK, I'll keep an eye on the page.
Thanks again.
