Lhaysfl
Jun 07, 2019Aspirant
R7500
Hello, I was trying to install updates I don’t know if there was a change to the security settings as a result of the updates. Updates now make it impossible to access internet, I get a access n...
- Jul 10, 2019
I will start with rebooting... thx
Jun 07, 2019Guru - Experienced User
Anytime you do a firmware update, its always a good idea to factory reset the device and do a reinstall. Did you update over wifi or a hardwired connection? Hardwired is best but isn't always an option for all.
I'd start with the reset if you didn't do that upon update if your R7500.
Lhaysfl
Jun 10, 2019Aspirant
Did the reset thanks
