Lhaysfl
Jun 07, 2019Aspirant
R7500
Hello, I was trying to install updates I don’t know if there was a change to the security settings as a result of the updates. Updates now make it impossible to access internet, I get a access n...
- Jul 10, 2019
I will start with rebooting... thx
Jul 10, 2019Guru - Experienced User
You could try a reboot.
You can also try changing wifi channels to 1-6-11 to see if that'll help.
You can even try setting the broadcast down from the up to 600mbps to see if that'll help.
Sometimes troubleshooting involves playing around to see what helps. Just make sure when you do it, you change one setting at a time so if something goes wrong, its easy fixed
Lhaysfl
Jul 10, 2019Aspirant
