Jetguy's avatar
Jetguy
routerlogin.net vs genie
What, if any, is the difference between logging into my c7000v2 by ROUTERLOGIN.NET or GENIE (PC Version-Windows)?  Do they both do the same?  If so, why use Genie over Routerlogin.net  I don't use an...
  • michaelkenward's avatar
    Mar 10, 2019
    It is your call.
    The desktop genie is a quick and easy way into various features in a modem and router.
    The browser has more controls, but take some navigating.
    Try them and see.
