Jetguy
Mar 09, 2019Aspirant
routerlogin.net vs genie
What, if any, is the difference between logging into my c7000v2 by ROUTERLOGIN.NET or GENIE (PC Version-Windows)? Do they both do the same? If so, why use Genie over Routerlogin.net I don't use an...
- Mar 10, 2019
It is your call.
The desktop genie is a quick and easy way into various features in a modem and router.
The browser has more controls, but take some navigating.
Try them and see.
michaelkenward
Mar 10, 2019Guru - Experienced User
It is your call.
Try them and see.
Jetguy
Mar 12, 2019Aspirant
Thanks MichaelKenward. I'll give genie a go.
