Mar 26, 2019Aspirant
Trying to use Genie to config DGND3700 router
I am trying to logon to my N600 router using the Genie app on my iPhone (app version 3.1.74, IOS 12.1.4 on iPhone SE) and all I get when I enter the correct password is:
Login Failed
NETGEAR ...
- Mar 26, 2019
And the genie support for version 2 might only be windows/mac support. Not app support.
https://www.netgear.com/support/product/DGND3700v2#download
23090619
Thanks for your reply. It looks like the router is V1 so that's a non-starter! I'll stay with the web interface.
michaelkenward
Apr 09, 2019Guru - Experienced User
Good move.
The browser on your iThings will give you much more control than the dumbed down app.
