anamvet
Oct 25, 2023Aspirant
unintall Genie
If I completly uninstall my old Genie21 will it somehow disrupt the operation of my new Nighthawk RAX54v2 router. I think it may be interfering, somehow, with downloading the 'Nighthawk' App?
- Nov 03, 2023
amelia2929
Oct 28, 2023Initiate
Uninstalling your old Genie21, similar to removing unwanted mods in FIFA Mobile, should not inherently disrupt the operation of your new Nighthawk RAX54v2 router. However, it's essential to ensure a clean uninstallation by following the manufacturer's instructions to avoid any potential conflicts or residual settings. Any interference with downloading the 'Nighthawk' app is more likely to be due to configuration issues or network settings rather than the removal of Genie21. Review your router settings and ensure that your new router is correctly configured to work with the app for a smooth experience. If issues persist, consider reaching out to Netgear's support for assistance.
anamvet
Nov 03, 2023Aspirant
