CDunn
Aug 12, 2021Follower
Wireless Router for VOIP with WISP Internet
Looking for a suggestion on the best wireless router to use for VOIP with WISP. I use this for work.
Aug 12, 2021Guru - Experienced User
The only netgear router I know of that supports wisp function is the netgear pr2000. Its an OLD travel router and I wouldn't recommend it.
If you're needing wisp functions, you'd be better off looking at a different manufacturer.
