thesohogeek's avatar
thesohogeek
4 Powerline (2 x PL1000, 2xPL1200) in one network
Hi
I've had 2 x PL1000 working fine over my mains network here for 2yrs. I wanted to expand and obtained 2 x PL1200 to "extend" the system.
I cannot factory reset ANY of these units, pressing the small button with a pin produces an obvious movement but nothing happens and the devices do not reset. So I am stuck with 2 pairs of units, each of which works with one other, and not 4 devices all using the same password to communicate freely between all.
How do I reset these units? I've donwload endless versions of Powerline Utility for Mac and Windows, none of them do anything useful - some see some of the devices but will not take control so are useless.
Is this really supposed to be as flakey as this? I'm about the throw the lot in the bin and buy another system that is guaranteed to work. That's a significant expense of course...
Has anyone any actual experience of making this work, and if so, how did you get the units to all share the same key?
thanks
    • thesohogeek's avatar
      thesohogeek
      Yes, and that process doesn't work.
      Hence the decision to try and factory reset all 4 devices and then start over. But factory reset doesn't appear to work either. What is the EXACT reset process and what feedback is provided to the user? Everywhere says "press the reset button". This is not clear. Is the unit powered up at this point? Or powering up? Or even powered off? How long do you need to press it for? How do you know it's worked?
      What is the point of Powerline Utility software that doesn't work? Google suggests many of these devices (from different manufacturers) share the same chipset and can use each others' software. If this is the case, what do people recommend, and can you provide a download link? I have Windows10 and MacOS machines to use to run it, anything will do to get this working...
      • michaelkenward's avatar
        michaelkenward
        In that case, I suspect something else is happening. I have been through that process many, many times as I move plugs around between networks. It has never failed on me.
        Unfortunately, "doesn't work" is a poor diagnostic aid. What does it mean? What happened when you tried? What were you doing and what went wrong?
        See above. What happens when you try?
        Press the reset "button" with power on. (Pointless doing it with a plug that has no power.)
        The lights should flash
        Very true, but generally the utility has very little use. Its sole role seems to be to disable power the saving mode that bothers some users.
        Is there something else you want to do with it? I find that the desktop Netgear Genie (Windows here) does what I need.
        genie | Product | Support | NETGEAR
        Look for the plugs bit of the Network Map.
        That's also the common refrain around here, which is probably where Google found it. It should also find one of the usual suspect. ZyXel's seems to be the most popular.
        This page is more helpful than anything that Netgear has written.
        [HomePlug] How to troubleshooting HomePlug/PowerLine adapters – Zyxel Support Campus USA
