sugaretto
Dec 14, 2019Tutor
401: Access to this resource is denied, your client has not supplied the correct authentication.
I just bought a plw1000v2 powerline and after I have updated his firmware from 1.0.0.16 to 1.0.0.18 I am not able anymore to login in the mywifiext . net with the default credentials (admin/password)...
- Jan 08, 2020Hi,
Check the firmware release notes. The standard password has been changed with the firmware update (it is now the same as the standard wifi password on your sticker). Good for safety but Netgear should have made it more clear before updating.
emanueleffe
Dec 19, 2019Aspirant
Hi sugaretto,
I have the exact same problem. After the update i can't log in anymore in my PLW1000v2 web interface. Have you found any solution?
I already tried to do a factory reset (multiple times) but nothing changes.
Thank you in advance.
- sugarettoDec 23, 2019Tutor
Hi,
unfortunately I'm still facing the problem. The Netgear support seems doesn't have any solution.
- PapignaJan 02, 2020Aspirant
Model: powerline PLW1000v2
Firmware version: V1.0.0.18
After upgrading firmware and tried to do many ad many factory resets I am not able anymore to login in the mywifiext .net with the default credentials (admin/password)
Is there a solution to this problem?
Thank you
- JohnieJan 08, 2020InitiateHi,
Check the firmware release notes. The standard password has been changed with the firmware update (it is now the same as the standard wifi password on your sticker). Good for safety but Netgear should have made it more clear before updating.- PapignaJan 09, 2020Aspirant
Thank You Johnie !
I can acces now
