sugaretto's avatar
Dec 14, 2019
401: Access to this resource is denied, your client has not supplied the correct authentication.
I just bought a plw1000v2 powerline and after I have updated his firmware from 1.0.0.16 to 1.0.0.18 I am not able anymore to login in the mywifiext . net with the default credentials (admin/password)...
  • Johnie's avatar
    Johnie
    Jan 08, 2020
    Hi,
    Check the firmware release notes. The standard password has been changed with the firmware update (it is now the same as the standard wifi password on your sticker). Good for safety but Netgear should have made it more clear before updating.
