sugaretto
Dec 14, 2019Tutor
401: Access to this resource is denied, your client has not supplied the correct authentication.
I just bought a plw1000v2 powerline and after I have updated his firmware from 1.0.0.16 to 1.0.0.18 I am not able anymore to login in the mywifiext . net with the default credentials (admin/password)...
- Jan 08, 2020Hi,
Check the firmware release notes. The standard password has been changed with the firmware update (it is now the same as the standard wifi password on your sticker). Good for safety but Netgear should have made it more clear before updating.
Papigna
Jan 02, 2020Aspirant
Model: powerline PLW1000v2
Firmware version: V1.0.0.18
After upgrading firmware and tried to do many ad many factory resets I am not able anymore to login in the mywifiext .net with the default credentials (admin/password)
Is there a solution to this problem?
Thank you
Johnie
Jan 08, 2020Initiate
Hi,
- PapignaJan 09, 2020Aspirant
Thank You Johnie !
I can acces now
