l39045's avatar
l39045
Follower
Oct 09, 2020
Access point compatible with Powerline PLP1200?
I'm aiming to improve WI-Fi coverage at my home.
I currently have four Netgear PLP1200 devices dotted around for wired device connectivity.
Is there a Netgear access point I can buy that will use the Powerline 1200 as a backbone / mesh / backhaul? Prefereably 5 GHz band.
Failing that I suppose I could buy a separate AP and connect into PLP1200 either directly or via a switch - suggestions welcome.
Open to other suggestions as well :)
Thanks in advance.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    That would work. It is what I have. Powerline front end for an Orbi in AP mode.
    You can buy Powerline plugs with a bundled AP plug, but you can't buy single plugs, just the bundle.
    PLW1010 | Powerline | Networking | Home | NETGEAR
    I'd use an AP. Much more powerful and with many more options.
