oshaughnessyb's avatar
Aug 19, 2019
Adding additional powerline adapter
I currently have a single pair of PLW1010-100NAS Powerline Adapters that are extending my WiFi network. For better coverage, I'd like to add two additional powerline adapters to the same network. I...
  • michaelkenward's avatar
    Aug 22, 2019
    You want to add two "wired" plugs rather than wifi plugs?
    Is is possible to purchase the just the slave end, or must they be purchased as a bundle?
    There is no such thing as "slave end" and "master" plugs. Both plugs can be "slaves" to an existing master.
    So, follow the instructions and you can use both plugs in a bundle to extend our existing network.
