Aidelimo
Jul 30, 2021Tutor
AV 200 Adapter XAVB2001
Hello, I have two Netgear Powerline AV 200 Adapter XAV2001 cpl sockets, I would like to buy two or three new Netgear cpl sockets to work together, but I cannot understand which model of socket to bu...
Aidelimo
Jul 31, 2021Tutor
Hello,
1)
So if I understood correctly, the four variants of the cpl plugs on the amazon link below, are compatible with those we already have?
2)
And also this wifi repeater?
NETGEAR Répéteur WiFi Mesh (EX7300), Amplificateur WiFi AC2200
3)
At the end of your answer you specify that there is only one need for a single source cpl socket. But when you buy the cpl sockets with two cpl sockets in a pack, is there necessarily a source cpl socket?
Or is it possible to buy "secondary" cpl sockets alone?
Thank you for your answers
Jul 31, 2021Guru - Experienced User
1. Yes the powerline device you linked to would work. But it'd only function at the speed of the slowest powerline device on your network.
2. That wifi extender isn't a powerline device. It could pick up and repeat the wifi signal from your router but it doesn't have integrated powerline so it wouldn't connect via that route.
3. It isn't "secondary" powerline device. You only need 1 that connects to the router and is the "source". the rest are added to the network its setup.
- AidelimoJul 31, 2021Tutor
Perfect !
Thank you very much for your time!
