Dendence's avatar
Dendence
Follower
Feb 16, 2013
AV 200 Wireless-N Extender Kit (XAVNB2001)
I plan on purchasing AV 200 Wireless-N Extender Kit for a friend. He has a large house and his Netgear wireless router is located in a corner first floor office.Right now his wireless signal to other parts of house is poor. The office is on a slab so there is no way to get cat 5 to other areas of house to add access points. I plan on putting the AP module upstairs but that leaves the other end of first floor that will probably need an AP. Besides the AV 200 Wireless-N Extender Kit can I add another AP module ? If so what is compatible with this kit ?
thanks you for help
1 Reply
  • you can have multiple XAVNB2001 connected trough the house using one single conection to your internet gateway, the you can have an AP (XAVN2001) in every floor, or any particular room you need wifi. You can connect any AP to the ethernet port of the powerline adapater there is not limitation, except that if you use a router (with firewall) insetad of a real AP, you will create another subnet in your network, it will slow down your througput in your new subnet, plus you would not be able to connect to other devices in your home in subnet1
