Xkeg4
Nov 14, 2025Follower
AV200 and LED light interference
Hi, I have been working for days to fix my drop outs of the powerline extenders I have in my study - I traced it to an LED up-light that I've had for 2 years, so I assume the bulb is dying and se...
Nov 15, 2025Guru - Experienced User
What testing did you actually do?
most issues I've ran into with powerline extenders are from other devices. Usually something going bad on the powerline thats injecting intererence.
You're best bet is to put the powerline devices on the same circuit and test them. If they run decent, its usually not the powerline devices. Its not always true because whatever is going bad could really be causing issues, but its the easiest test.
But the AV200 is a pretty old device and old standards. Sadly, netgear really hasn't been in the powerline market much.
