Mayagrafix
Feb 27, 2013Aspirant
AV200 kaput?
Had this kit for just about a year, it has worked flawlessly untill today. It now fails to make a connection (no green or amber light in the Powerline Led). I switched both modules on and off, and eve...
jmizoguchi
Feb 27, 2013Virtuoso
if works in the same room then something is causing on different breaker.
look all the appliance that is plug on circuit and remove and test again.
