Adrian316
Mar 24, 2021Aspirant
Can I plug my PLP1000 powerline into a 3 way adapter?
Hi - hope someone can help please? In the room where Ive got the router, there isn't enough space between the wall outlet and the alarm box above it for the powerline PLP1000 to sit due to it's h...
michaelkenward
Mar 26, 2021Guru - Experienced User
To answer the question in your subject, yes. Netgear warns against extension blocks and the like, but I do this all the time with no discernible damage to the network.
Adrian316 wrote:
Any help / advice greatly appreciated.
Is that it? I see no questions or issue in the rest of your message.
Adrian316 wrote:
SKY Q has been configured to connect via the ethernet cable and the 2.4GHz and 5GHz recievers have been turned off in settigns (useful trick Sky told me about this morning to access a hifdden menu).
I don't know what that is about.
- Adrian316Mar 29, 2021Aspirant
Hi MIchael
yes that's it thank you - much appreciated.
