Bsquared64
Oct 01, 2020Follower
Cascading multiple access points off of a single PLW1000v2 adapter
I have been using the PLW1000v2 adapater & single access point for over 2 years and love it. I moved into a new house and would like to add a second access point to the existing adapter. However, I c...
michaelkenward
Oct 11, 2020Guru - Experienced User
Bsquared64 wrote:
However, I can't find access point only product other than the universal NetGear access point.
Netgear and most others don't sell single plugs, AP or otherwise.
I don't know what you mean by "universal NetGear access point". Is that a particular model number?
You can use a Powerline plugs as the wired Ethernet front end to any wifi access point that takes your fancy.
