xtremepercy
Jan 05, 2012Aspirant
Connection difficulties with 2x Powerline AV 200 adapters
Hi and thanks for taking the time to read this, Im having some difficulty in determining whats wrong with my powerline adapters and their setup so was hoping to get some help. I have internet conn...
JeTmAn81
Jan 27, 2012Novice
xtremepercy wrote: They werent connected on the utility no but since posting theyve just randomly began to work again and ive not had any issues since the 5th. I can post an ipconfig from when theyre working if that will help but it just seems as though either one of the adaptors is temporarily playing up or theres some strange variable that keeps affecting their connection every now and then.
FYI, I have been having pretty much the same issues with my AV200. I installed the adapters back in November, and they've been working great until earlier this week when the connection dropped. At first I wasn't sure if it was the powerline adapter or some other part of my network, but after much fiddling around with various components I finally reset both adapters to factory settings, re-paired them and they started working again.
Until last night, when they stopped working again and that same process did not revive them. So my thinking is that it's pretty clear that it's the Netgear adapters which are the problem, since multiple other devices connected to my network via wireless and wired connections are working fine. I even switched over my Playstation 3 (the device which is using the powerline adapter) to wireless, and that was able to connect to the internet just fine, albeit with a pretty slow connection, which is the reason I got powerline adapters for it in the first place.
So it's the same issue but unfortunately I have no idea why it's happening. There have been a few things added to my house's electrical grid lately (heaters, a computer, etc.) but I don't know if that would be enough to choke out the available bandwidth or something like that.
