xtremepercy
Jan 05, 2012Aspirant
Connection difficulties with 2x Powerline AV 200 adapters
Hi and thanks for taking the time to read this, Im having some difficulty in determining whats wrong with my powerline adapters and their setup so was hoping to get some help. I have internet conn...
PhuKew
Mar 18, 2012Novice
I've researched this problem [Local Area Connection doesn't have a valid IP configuration] and have yet to find a solution. I've tried all the suggestions i've found, none work. I have four powerline adapters but can not get more than two to work at the same time. The addition of the third and/or fourth just wont work. I have three desktops I want on the powerlines but am stuck with the third desktop on wifi. I went with the pwrlines because I was too lazy to string cat5 in my new home and wifi just wasn't reaching the farther reaches of my home. I know it's not my house wiring because i can get may laptop to join the network from any outlet in the house as long as only one PC is on the network. As soon as i attempt to add the third i'm out of luck. I keep reading that you're supposed to be able to add just about as many as you want (don't know if there is a limit) but for me I have two additional units I can't use. Considering all the time and effort I have spent trying to fix this problem I could have strung the cat5 twice over. Anyone out there having similar multi adapter problems?
