ACrazedBear's avatar
ACrazedBear
Follower
Mar 17, 2022
Connection from PLP2000 slow
Hello,
I am currently trying out a PLP2000 Powerline Adapter. Seems to work but I have noticed that it seems to limit my connection.
Current Setup:
Coax Cable > Netgear CM1200 Modem > AC1750 Router >  PLP2000.
When running some tests I can get around 100mbps through the PLP but can get around 200mbps from a direct connection to the router.
I have tried
- re-syncing the connections
- restarting the router and modem
- tested the receiver in a closer outlet as well as an outlet further out and see the same results.
I was thinking about trying a router or connecting to the modem directly just to see if it's the router but have not had time yet.
Any suggestions would be appreciated.
