noiseoptics
Feb 17, 2012Novice
correct XAVNB2001 setup??
Hi, I've been trying today to set up the two home-plug adapters XAV2001 and XAVN2001 and have successfully managed to use the WPS button on my Netgear router to set up the XAVN2001 which has now been ...
laurent27
Feb 27, 2012Aspirant
Hi i'm Laurent,
About your problem, try to connect to 192.168.1.40 (at my home it's my XAVN2001 ip adress) and you'll be able to specify any passssword you want for the new wifi network the netgear XAVN2001 has created during its installation.
If you don't find the ip adress, connect to the ip adresse of your internet router (like 192.168.1.1 or something like that).
happy to help you. Tell me if it's working.
Regards
Laurent
Regards
Laurent
