adfgdsfgsfhg
Dec 28, 2019Aspirant
Does Powerline 1200 get better range than Powerline 1000 even if not achieving max speeds?
I got a pair of the 1000 Powerline adapters to get internet to another property with a separate electrical service but on the same transformer, and surprisingly it works quite well; however, the ligh...
adfgdsfgsfhg
Dec 29, 2019Aspirant
Yeah I am stretching the PL1000 to the limit. I get around 10Mbps. So you're saying that with the low signal quality, a more expensive model won't make much or any difference? Is that based on your experience? If the PL1200 will even just get a few more Mbps I think it would be worth it...
michaelkenward
Dec 29, 2019Guru - Experienced User
That doesn't sound good.
I have PL1000s on my network. They are a lot faster than that.
I use them to feed an Orbi in access point mode. This speedtests at 45 Mbps wifi on 60Mbps Internet.
That sounds right. I have 500 Mbps plugs that run faster than you experience.
- adfgdsfgsfhgDec 29, 2019Aspirant
michaelkenward wrote:That doesn't sound good.
Yeah but do yours operate with green lights or yellow/red?
The fact that I can get at least 5Mbps reliably is still impressive for this application, considering it's going through a meter, probably hundreds of feet of overhead service lines (I'm not really sure but it's a long way) with the transformer in between, and through another meter. I didn't think it would work but I got a green light the first time I plugged them in! But router and other stuff makes it yellow or red; I did get alternating yellow/green when plugged into a separate RV outlet and I think I might've seen 20Mbps. (Also the signal quality is surprisingly similar on either phase; I had a hard time figuing out which phase the other end was on.) So I will install a dedicated outlet to minimize interference. But in an effort to maximize results I'm wondering if getting a different model would help while there still is time to return.
But with a better connection? It would be interesting to see the difference in speed between a PL1000 and PL1200 and that cheaper 500 one when tested at the same locations that makes the light yellow or red on the 1000. Unfortunately there does not seem to be such information out there so that leaves only one way to find out...
I've seen some people say that the more expensive adapters will always be faster but others say not because the faster adapters use higher frequencies which don't go as far. It would be very interesting if the cheaper adapters actually get better speeds, but they'd be a bit more difficult for me to get to find out...
BTW, what are some other ways to minimize interference and maximize speed? Would ferrite RF filters on the other circuits help?
- michaelkenwardDec 30, 2019Guru - Experienced User
I have used Powerline plugs through a junction box to test – the results were not good – but two meters and overhead cables is well outside the specifications. Netgear even advises against using power blocks.
The whole idea of powerline is that everything is on the same local mains circuit, not running half way round the country.
