jkimbro
Feb 17, 2020Tutor
Double duty POE
Hey all,,, I'd like to do a ethernet over power thing,,but then the output would be POE. Hopefully that makes sense. Do they have a Powerline adapter that does both or do I need to get a powerline a...
- Feb 18, 2020
Have NEVER seen a Powerline adapter (from an manufacturer) that outputs PoE. This needs a separate PoE "injector" or switch.
CrimpOn
Feb 18, 2020Guru - Experienced User
